VAIO DVD Player Region Hack?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Lex, May 9, 2002.
  1. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Hi all,
    Can any of you help me?
    I have a Sony Vaio laptop with an internal DVD-Rom drive which I would like to convert to multi region. However, as it would be a hell of a lot more expensive to replace than a standard desktop one I am loath to risk damaging it!
    Has anyone ever hacked one, or know someone who has? I have done some searches on the web, but can't find anything! :(
    Any advice appreciated!
    (Sony VAIO FX series)
  2. Spunky
    Spunky
    Jan 8, 2002
    113
    19
    Norwich/Liverpool
    I modded my compaq amarda dvd-rom a few weeks back, so in theory the procedure i used should be the same.
    1) Use cdinfo to find the exact make and firmware revision your dvd-rom is using ( //www.cdvdinfo.subnet.dk/ )-also see if its locked to a region or region free already. If it is skip the below step.
    2) Look up your firmware on
    //perso.club-internet.fr/farzeno/firmware/
    Then download the PATCHED firmware from the same place-making the drive region free.
    Just read all the disclosure stuff to otherwise you might wreck your drive.
    3) On top of that any dvd SOFTWARE also needs to have its region code bypassed. I recomend dvdgenie. I think thats also on the above link.
    I think thats it,
    Spunky
