VA555ES 2 Way Remote Control
Discussion in 'AV Receivers & Amplifiers' started by rmcphail, Feb 24, 2003.
  1. rmcphail
    rmcphail
    Jan 2, 2003
    35
    I cant seem to get the 2 way communications on my Sony VA555ES to work, amp and remote are set to AV1 and 2way comms are set on the amp .Does anyone have any info for me or am i missing somthing . The remote does not switch on the amp when the selector is pressed but does when the stanby button is pressed. Please help getting fed up now , head starting to implode !!!!!
    Thanks :hiya: :lesson:
  2. rmcphail
    rmcphail
    Jan 2, 2003
    35
    :p :smashin:
    Does no one know the answer !!!!
  3. iwatkins
    iwatkins
    Did you post the same question on the Usenet ?
    Anyway, have you initialised the remote following the instructions in the manual ? If not do that as my remote didn't do two-way until I had done that.
    Ian
  4. rmcphail
    rmcphail
    Jan 2, 2003
    35
    I disconnected the s-link connector then re powered the amp , and presto 2 way communications. I tried Sony customer help line and was told there was a fault on the amp and should return it for repair.
    Any way ima now happy and will pass on my info to you guys if you need it. Thanks
    :clap: :clap: :clap: :laugh: :laugh: :hiya: :hiya:
  5. ditton15
    ditton15
    Oct 20, 2002
    535
    16
    edinburgh
    glad you are happy, but tell me: surely 2-way communication with remote seems to imply that the amp can get you to do things - or maybe it just has :D
  6. rmcphail
    rmcphail
    Jan 2, 2003
    35
    Sorry dont understand question.:eek:
  7. ditton15
    ditton15
    Oct 20, 2002
    535
    16
    edinburgh
    not really a question - just the ramblings of the deluded. Sorry to confuse. :clown:
