v3000 sd settings best i can get
Discussion in 'LCD & LED LCD TVs Forum' started by crashuk, Jan 22, 2008.
Tags:
  1. crashuk
    crashuk
    Jun 2, 2007
    675
    28
    +47
    picture standard
    back light 6
    contrast 63
    brightness 45
    colour 53
    colour temp neutral
    sharpness 4
    noise reduction low#
    mpeg low
    advanced
    black corrector off
    adv contrast off
    gamma low
    clear white high
    live colour off
    colour space wide
    theater mode off
    screen format 4:3
  2. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    You should try lowering the sharpness to min, backlight to 5, and clear white to off.
    Also set it to 16:9.
  3. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    MPEG NR should also be off, unless you're watching Digital TV.
    Also, I think you should be able to get away with maximum Contrast on this panel.
  4. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    Going pass 90 will slightly over bloom the whites
    85-89 should be fine
    PS: The MPEG NR does help but it should be set to low.
