V3 Razr and Mobile phones tools problem
Discussion in 'Mobile Phones Forum' started by Warp, Apr 15, 2005.
Tags:
  1. Warp
    Warp
    Jan 5, 2005
    69
    I have bought mobile phone tools but have a problem getting the Multimedia Studio to open. When I click on the icon, all that happens is it loses the connection with the phone and then re-initialises. I am using a USB cable to connect.
    Do anyone know how I can get the Multimedia Studio to open up?
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I had a similar problem when I used the software for the first time. It worked once, then wouldn't find the USB connection again, even though the PC played a sound when I plugged the phone in. I cured the problem by un-installing the software, then re-installing it again.
  3. Warp
    Warp
    Jan 5, 2005
    69
    thanks. Have already tried re-installing with no success. Will try again though.
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Make sure that you reboot the PC between un-installing and re-installing, to make sure all the drivers are unloaded.
