V2 Box
Discussion in 'Satellite TV, Sky TV & FreeSat' started by raven219, Sep 30, 2004.
  1. raven219
    raven219
    Mar 5, 2001
    546
    East Anglia (well someone has to live there!)
    +19
    Had the engineer last week to take away my sick V1 box. He left a V2 box instead. Should the fan make that much noise?
    Mind you the menus are so much quicker!
    Raven
  2. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    Bradford, West Yorkshire.
    +324
    In a word - no!
    I can honestly say I've never heard the fan on my Pace 3100 (v2).
    Get 'em back!
    A. Dork
  3. Jules
    Jules
    Oct 11, 2000
    5,629
    134
    +1,116
    Well, I have a V1 and V2.
    The V1 is much quieter, and it was for precisely this reason that I switched the location of the boxes so the V1 didn't intrude on late night listening.
    I don't think your V2 is faulty, but if you been used to a V1 then its hard going back.
    That said, my V2's fan only decided to stay on 24/7 after upgrading the HD to 120G (even though the HD doesn't get hot at all). Prior to changing the HD, sometimes it was quiet but sometimes it was noisey.
    The V1 is always quiet, and only makes a slight hum even when the fan comes on.
  4. shoestring25
    shoestring25
    Feb 2, 2003
    4,099
    essex
    +565
    yes the fan is that loud on the v2 box. mine is
  5. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    +324
    It's faulty then! :devil:
    Do you watch telly with your ear to it? :D
    A. Dork
  6. shoestring25
    shoestring25
    Feb 2, 2003
    4,099
    essex
    +565
    the fan got louder after the last software update and comes on more often
    yes i can hear it when i sit in my living room without the tele on.
  7. johndon
    johndon
    Feb 3, 2002
    1,988
    63
    +122
    I can hear the fan on my v2 box if there is no other sound in the room. It's also on all the time which only seems to have happened since the last software update.
    John
  8. bigbak
    bigbak
    When the engineer fitted my box he told me the fan noise was normal and not considered a fault.
    He'd been called out the previous week because of it and the person was charged a £65 call out.
    It's normal. The gubbings needs cooling, and the fan kicks in when it's hot inside.
