V+ unavailable
Discussion in 'Cable TV & Virgin Media TV' started by mr bluesky, Apr 27, 2007.
  1. mr bluesky
    mr bluesky
    Jun 29, 2005
    Hiya folks
    sorry if this has been poster before.
    we have two V+ boxes in the house both working fine..until this morning when I went to play back a film I had recorded I pressed the V+ button and got....
    "ATTENTION you're not subscribed to V+"
    with error code 2001
    I press the record button and get
    " V+ is unavailable Please try later"
    the V+ box downstairs is fine
    I rang Virgin and was told it was down to there being a software upgrade
    Helllllllllllppppppppppp
    Many thanks
    Blue
  2. zico martin
    zico martin
    Oct 2, 2005
    424
    +4
    if i had to stick my neck now i'd say they are probably doing a software upgrade
  3. Ben
    Ben
    Feb 19, 2007
    1,417
    Tunbridge Wells
    +263
    If I also had to stick my neck out, I'd say it's because he's trying to use the V+ remote with the V= box...
    I heard they're incompatible ;)
  4. mr bluesky
    mr bluesky
    Jun 29, 2005
    nope using V+ remote with V+ box
    also if they are new v+ boxs should they need a software upgrade
    and why is the other one ok?
    they are both V+ boxs
    oh well another phone call tomorrow
    Blue
