Component is an analog signal while HDMI is digital, therefore HDMI is generally better than Component. If you have the option to use HDMI, I would use it. Most On Demand requires itmad: ) and the picture generally is better. Only use component if you don't watch alot of HD on demand
The problem I have now is when the PS3 arrives in the next couple of days do I use the component or get another HDMI cable and just swap the HDMI cables connecting to the DVI adapter when I want to change devices.....why cant anything go smoothly?![]()
Can't you buy an HDMI to DVI cable, or another HDMI cable + HDMI to DVI adapter like you already have done. Then just select the input source using your DVI switch? I imagine swapping the cables will soon become a pain in the butt - especially if the cabling around your TV looks anything like mine!![]()
I never thought that I had.Joe Fernand said:you have not stumbled on to some magical HDMI/HDCP fix-it
Exactly,that and the inclusion of the adapters,I wasnt optimisic that I would get any joy.If I was unable to view the HD movies before but now I can doesnt that mean they were encrypted?Or just that they only work through HDMI?Joe Fernand said:I guess the 'surprising' bit about your new set-up is that the low cost DVI switch is HDCP enabled - that assumes the V+ box is actually outputting an HDCP encrypted signal to begin with!
Yup,I suspect it will be component for that baby as long as I dont get more encrypted problemsJoe Fernand said:The PS3 may be a sterner test for your switch - the PS3 has proven to be very unforgiving in terms of system connectivity
Hello Mr Jason B
The ability to 'deny service' on the Analogue Outputs of the V+ box is separate from the addition (or lack of) of HDCP encryption on the HDMI Output.
HDCP is not mandatory on HDMI connections - though most Content/Rights owners will insist it is applied; even on SD Outputs.
Joe
Just another thought ---- I was told that if you didn't get an HDMI cable when you first got the v+ box, you could ring Virgin and they would send you one in the post.
BTW The one they supplied me was faulty and the picture used to blank out for a couple of seconds every now and then, eventually becoming several minutes. The first enginner said it was the box, swapped it and no change. The second said he had had other people with this problem and it was the cable and recommends they go out and buy one. I changed mine and that fixed the problem.
