V+ HDMI & Optical close?
Calzor Suzay
Has anyone else had a problem connecting up both a HDMI cable and an optical link on the back of the V+ box?
I can't plug the two cables I have in at the same time as they hit each other, the HDMI I bought and the toslink connection I already had.
Any recommendations on a toslink cable that has a small head so it won't intefere with the HDMI when I try plugging it in?
Racquel Darrian
Had the same problem.
I switched cables to one with a smaller HDMI connection.
Yokomo
no problems for me, i have a relativley 'beefy' HDMI and Optical cable, although it is tight fit
Calzor Suzay
I found a toslink to minijack presumably for an old MiniDisc player I had once, that fits fine but obviously the other end is wrong. Local maplins cheap and cheerfull £9.99 one even comes with a chunky connection. I might have to introduce my hacksaw to the HDMI connector at this rate ;)
Racquel Darrian
Out of interest I have found the HDMI lead supplied with the V+ box, by VM, is not as wide, at the connector, as my 5 metre one.
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
