v.c.d,s on the main t.v
Discussion in 'Desktop & Laptop Computers Forum' started by ianlecompte, Aug 13, 2003.
  1. ianlecompte
    ianlecompte
    Sep 17, 2002
    951
    oxfordshire
    +13
    hi folks,just a quick question.t.v card has a single jack out.what lead do i need to connect to t.v in lounge to watch my video c.d roms? or do i connect to the video.any advice would be helpful.many thanks.:clap:
  2. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    If it is a phono socket (usually yellow), then it is composite video. It can be plugged into composite input if you have one, or SCART via a suitable lead. The audio is taken from the sound card, and can be fed into the SCART with the same lead, or audio phono inputs if fitted.
    If it is multi-pin then it is s-video, and you will need an s-video input on the TV
  3. ianlecompte
    ianlecompte
    Sep 17, 2002
    951
    oxfordshire
    +13
    thanks gab,thats a greati,ll search for one now,all the best
  4. ianlecompte
    ianlecompte
    Sep 17, 2002
    951
    oxfordshire
    +13
    i meant to say a great help,thanks again
  5. Pack Dude
    Pack Dude
    Feb 6, 2002
    870
    Lost In Space
    +98
    What TV card are you using? I have three TV cards none of them have a video output just inputs.
    My radeon graphics card has a s-video output which can be used to display the desktop on a telly.
  6. ianlecompte
    ianlecompte
    Sep 17, 2002
    951
    oxfordshire
    +13
    hi packman,its a wintv32 card it has a vid input/output?
  7. Pack Dude
    Pack Dude
    Feb 6, 2002
    870
    Lost In Space
    +98
    I think wintv32 is the software for the Hauppauge TV cards. Do you have a model number?
    I think you will have to use the video out on your graphics card if it has one.
  8. ianlecompte
    ianlecompte
    Sep 17, 2002
    951
    oxfordshire
    +13
    dont know the model no.and i,m pretty sure the graphics card does not have a video out,does this mean i cannot do it?thanks for your help
  9. Pack Dude
    Pack Dude
    Feb 6, 2002
    870
    Lost In Space
    +98
    You might be able to find the model of your TV card in windows device manager. Under Sound, video and games controllers.
    What graphics card do your have? Many have an s-video output, a little round black female plug.
    To tell you the truth ive only used the s-video out from my card once it looked okish to me but most people say its pants but for VCD i guess it might be ok.
    I use the VGA out to a projector why dont you buy one :)
  10. ianlecompte
    ianlecompte
    Sep 17, 2002
    951
    oxfordshire
    +13
    878/9 vfw that is maybe the no.?graphics card is what came with the p.c cant see such a plug
  11. ianlecompte
    ianlecompte
    Sep 17, 2002
    951
    oxfordshire
    +13
    whats vga out?.i dont think the budget monitor would approve of a projector but yeah great idea,i,m hoping to borrow one soon and build a huge screen with some canvas or such like
  12. Pack Dude
    Pack Dude
    Feb 6, 2002
    870
    Lost In Space
    +98
    If you DONT have any video outputs you can always buy a new graphics card with one.
    Or mabe someone else on the frums has a better idea.
    VGA = Video Graphics Array or the plug on your graphics card that monitor plugs into.
  13. ianlecompte
    ianlecompte
    Sep 17, 2002
    951
    oxfordshire
    +13
    thanks packman i,ll look into it
  14. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    All the new TFT TVs coming out now have a TV tuner (analogue), s-video, composite and either SCART or component inputs, plus remote control, and are excellent value. I have just ordered the Relisys 17 inch widescreen for £421 plus carriage:
    http://secure.addonsonline.co.uk/addon/code/products.asp?recid=458&subcatid=32
    Also does picture in picture so you get the best of both worlds, a TV, computer monitor and plug your set-top DVD into the component inputs!
