v+box
Discussion in 'Cable TV & Virgin Media TV' started by tonynev, Apr 27, 2007.
  1. tonynev
    tonynev
    Apr 14, 2007
    123
    +6
    when i am in my settings menu, i am trying to save my settings to
    hidef component and 720 wide. but each time i click ok and test,after the screen returns, the original settings are shown, it wont let me save new settings. does anybody know the answer. thank you.
    ps: i have tried all combinations for hi def and wide, with the same
    results.
  2. adam_priest
    adam_priest
    Dec 3, 2006
    24
    I seem to recall that you have to press text to save the settings.
  3. davyi
    davyi
    try changing your settings but before you press the final button to test, turn your tv over to the hi def channel. somehow the v+ box detects if a picture is shown (poss through your hd conection) and reverts back to original settings if not. Hope this helps.
  4. bjjgann
    bjjgann
    Nov 17, 2004
    231
    +17
    You need to switch your TV to Component after pressing OK and you will see a screen saying press text if you see this message. Some TV's will switch over automatically but some dont.
  5. Shanx
    Shanx
    Tony
    Did you have any luck with getting your HD settings working? I am having the same problem I have had some one out from Virgin to no avail, the guy only seemed to have the basic knowledge, so I am still stuck without HD.
    My TV is a Sony 26" Bravia kdl26s2030 is there any thing i need to do to this before adjusting the V+ settings?
    Shanx
  6. tonynev
    tonynev
    Apr 14, 2007
    123
    +6
    shanx. i'm still in the dark after trying several options. the fella that fitted my v+box couldn't even fit my lead , he said he wasn't insured if anything went
    wrong. rang customer services friday, someone will contact me within 3 days.
    what a joke!
  7. Shanx
    Shanx
    The guy that came out to me gave up after about 50 mins and told me he was going to re-schedule me for this Friday:confused: Hopefully this time they send some one with some knowledge of what to do:)
  8. Starfleet
    Starfleet
    Aug 16, 2005
    157
    Birmingham
    Adam Priest is correct you have to press txt on the remote to accept new setting
  9. Shanx
    Shanx
    Tony
    I'm not sure how but I managed to get my v+box to accept the HD settings, these are the steps I took, as far as I can remember, so hopefully they will help you.
    Go to the set up page and select the Hi def hdmi and the res you want.
    I then pressed the text button on the virgin control and got an error msg & pressed OK to reurn to the settings page.
    Then pressed OK to save the settings, when the screen went blank i pressed the text button again and waited. This time I didn't get a picture back on the AV2 channel that I was on. So I switched to AV4 which is where the HDMI cable is connected on my TV and hey presto HD TV.
    I hope this makes some sense as it was all done in hope rather than with any real knowledge.
    Good luck
    Shanx
