V+ box via Component
Discussion in 'Cable TV & Virgin Media TV' started by don-tucker, Jan 15, 2008.
  1. don-tucker
    don-tucker
    Aug 9, 2005
    298
    Hi,I'm having the Virgin V+ box installed next Tuesday and would like to use thr component out to connect to my Panasonic Plasma display panel ,can I expect any problems ? Please
    Don
  2. BikeNutt
    BikeNutt
    Sep 5, 2006
    1,205
    48
    London
    +78
    You won't be able to watch HDCP content (PPV HD Movies). Otherwise fine.
    HDMI looks better if your TV supports it though.
  3. Ben
    Ben
    Feb 19, 2007
    1,417
    Tunbridge Wells
    +263
    Might be worth you trying a cheap HDMI to DVI cable to see how that looks, before spending decent money on component cables - unless your DVI port is already in use. You'll still have the same HDCP issue, though that's not the end of the world.
  4. dan1979
    dan1979
    Sep 16, 2004
    3,539
    83
    +218
    I don't know about that screen but HDCP can be carried over DVI just fine.
  5. Ben
    Ben
    Feb 19, 2007
    1,417
    Tunbridge Wells
    +263
    It's last gen or so. No HDMI or HDCP enabled DVI.
  6. don-tucker
    don-tucker
    Aug 9, 2005
    298
    Thanks for the replies Guys,yes the panel is older generation,like me,but is still a nice picture,I have bought a component input board and will buy some "middle of the road" cables and just keep my fingers crossed.
    Don
  7. markp
    markp
    Sep 27, 2003
    258
    28
    Derby
    +25
    I have a older generation Pioneer plasma that I connect to the V+ box via component and the PQ is very good.
  8. don-tucker
    don-tucker
    Aug 9, 2005
    298
    Thats whant I want to hear,thanks Markp
  9. Twilight zone
    Twilight zone
    Jun 9, 2006
    72
    +4
    I've got the 42" version of your panel and connect it through the component input on the tuner that I have.
    PQ is quite simply astounding, and when I have seen HD set ups it has not tempted me in the slightest to upgrade - I bought £7.99 JVC cables.
  10. Nottman
    Nottman
    Dec 11, 2002
    208
    Gtr. Manchester
    +5
    Mine's connected to my Pioneer PDP428XD through component - can't tell the diff in HD or SD between this and HDMI
  11. NW3
    NW3
    Dec 24, 2005
    279
    +11
    I've never read anything that says HDMI offers better quality pictures. At best it's even I think . I was told by my AV installer and another that didn't get the job that they though Component was better. HDCP is the only reason to have HDMI if you think that's going to be an issue....
  12. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    I'd fully agree with this, I've got the V+ attached to my PWD8 via component and it's superb :thumbsup:
    I wouldn't worry about the HDMI, the signal is not going to be better, it is just going to allow you HDCP connection for HD movies. But then again, as the PWD's are all SD, why would you purchase the HD movies anyway :rolleyes: Don't get me wrong, HD looks really good on the PWD's panels, but then again, SD looks great as well :smashin:
  13. don-tucker
    don-tucker
    Aug 9, 2005
    298
    Can't wait now,ordered the cables and input board,the +box coming Tuesday so after all your comments should be worth waiting for.I have got the DVD recorder running through component and that's good PQ.I will sell my JS converter.
    Thanks again Don
  14. wese007
    wese007
    Sep 28, 2006
    593
    28
    scunthorpe
    +52
    i tryed to use component with my V+ box ,im getting no picture though,sounds is coming throught ok though,any ideas guys,telly is a panasonic th-42pz70 if that needs noteing,
    any ideas guys please
  15. markp
    markp
    Sep 27, 2003
    258
    28
    Derby
    +25
    Have you changed the settings on the V+ box to HiDef component?
  16. wese007
    wese007
    Sep 28, 2006
    593
    28
    scunthorpe
    +52
    yes buddy,played with all settings,the component on the tv is fine,as i use to use it for my xbox 360,so i can rule out faulty part on tele,
  17. wese007
    wese007
    Sep 28, 2006
    593
    28
    scunthorpe
    +52
    sorted now,today was a better day for me,god knows what i did wrong yesterday lol,cheers
