V+ box to packard bell viseo 230 dvi to hdmi - input not supported???
kevVM
Hi ive searched hard online and cant solve this issue i have a packard bell viseo 230ws and a virgin media v+ box. i ham trying to connect using a hdmi to dvi cable. the input on my pb is dvi. I was advised to purchase a dvi to hdmi adaptere to get it working as all i get through the dvi to hdmi cable is "input not supported" . has anyone had any oy connecting this way. ive tried playing around with the settings of the box but no luck so far. please help it would be hugely appreciated. audio isnt an issue as i can connect dssome speakers once its working...
Thank You :):):):):)
kevVM
this is the spec of the monitor if it helps
Product Type
LCD Monitor
Number of Screens
HDCP Supported
Yes
Green Compliant
Yes
Green Compliance Certificate/Authority
MPR II
VESA Mount Compatible
Yes
DVI
Yes
VGA
Yes
Product Family
Viseo
Colour
Black
Brightness
300 cd/m²
Colour Support
16.7 Million Colours
Maximum Resolution
1920 x 1080
Brand Name
Packard Bell
Contrast Ratio
8,000:1
Screen Size
58.4 cm (23")
Aspect Ratio
16:9
Response Time
5 ms
Speakers
Yes
Built-in Devices
Speaker
Horizontal Viewing Angle
160°
Vertical Viewing Angle
160°
Standard Refresh Rate
75 Hz
Weight with Stand (Approximate)
4.80 kg
VESA Mount Standard
100 x 100
Operating Power Consumption
70 W
Standby Power Consumption
1 W
Height with Stand
286 mm
Width with Stand
509 mm
Depth with Stand
132 mm
Screen Mode
Full HD
Manufacturer
Acer, Inc
Product Model
230Wsbmd
Product Name
Viseo 230Wsbmd Widescreen LCD Monitor
Product Line
Viseo
Input Voltage
220 V AC
Manufacturer Part Number
ET.D150C.004
Trollslayer
75Hz - the V+ box will be looking for 25Hz.
Trollslayer
Not at all I'm afraid.
