V+ And The Set Up For Recording To Dvd Recorder
GARY-M
I haven`t tried this yet but can someone tell me the correct way to set up the v+ box to my dvd recorder,so i can make sure i do it right the first time.
Thanks.
t11rmh
Established Member
Conect your DVD recorder to the second scart cable of the V+ Box (the lower one at the back). Then use the copy to DVD/VCR feature on the V+ box and make sure your DVD recorder is recording form the right input that the scart is in.
t11rmh
Established Member
The V+ Box can record two different programs, whilst you watch a third and copy to vcr all at the same time. I do this regularly. Great bit of kit...
P
philws
What sort of connection can you use to connect to your DVD/VCR? I assume SCART... is it composite or RGB? Or is this selectable?
bowler
If you copy from the VCR scart its composite.
If you copy from the TV scart its RGB.
The latter is fiddly because you cannot output from the TV scart and the high definition connection at the same time.
⭐ Philips OLED+908 TV preview + Avid Accent amplifier reviews + Hi-Fi & AV News
Back
