Using XBox as a DVD player
C-Man
After some advice...
I'm thinking about buying a few Region 1 DVDs, the only problem is my DVD player only plays Region 2.
Would I be able to play the R1 dvds through my Xbox?
C.
John
C.
Look up the softmod/xbmc thread . It will then play anything you throw at it, as well as being everything MS wished the dould have charged you for
John
triplea4uk
XB is great what you can do with it and stuff but I would recomment buying a budget dvd player you can get ones for £25 that can be turned to multi region.
