Using Xbox 360 Joypad on Windows Xp
Discussion in 'PC Gaming & Rigs' started by chrislad, Mar 24, 2006.
  1. chrislad
    chrislad
    May 6, 2005
    5,862
    83
    Rep. of Ireland
    +153
    I heard this was possible. I have the play and plug kit, which comes with a USB cable, however, the hardware is not recognised.
    Any ideas?
  2. Rasczak
    Rasczak
    Apr 3, 2002
    22,752
    Warwick
    +3,394
    AFAIK it's only possible to use the wired version of the controller. The wireless model, even when connected via the Play & Charge kit, is not compatible. There were some rumours that MS was planning to add support for it - but I've heard nothing since.
  3. chrislad
    chrislad
    May 6, 2005
    5,862
    83
    Rep. of Ireland
    +153
    That's pretty dumb, and unfortunate. They want you to buy the most expensive model, yet only the cheaper model works? Madness :)
    Thanks!
  4. Mattk84
    Mattk84
    Feb 20, 2006
    3,547
    Weymouth,Dorset
    +135
    I guess they thought that most people would want the wireless controller for their 360's so they needed another selling point for the wired controller ie pc compatability.
