Using xblive account on a second xbox
Discussion in 'Xbox Forums' started by harrisuk, Jan 18, 2005.
  1. harrisuk
    harrisuk
    Jan 24, 2003
    5,326
    71
    +58
    Can this be done ? I want to use it on my second box downstairs (Obviously not at the same time) Is it possible to set it up on more than one xbox if so how ?
  2. ozzyo99
    ozzyo99
    Dec 31, 2002
    154
    London
    +3
    Nope isn't possible if only because it registers your HD serial to prevent people freelancing it about.
  3. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,893
    2
    Manchester
    +4,429
    It is perfectly possible to put your Live account on any Xbox you see fit. I've got two Live accounts on both of my Xboxes and both work fine. The difficulty is transferring them, you'll need some kind of memory card to copy it onto, and then you can copy from the memory card onto the other Xbox. What isn't possible is to have the same account running simultaneously in two places at the same time, obviously.
  4. harrisuk
    harrisuk
    Jan 24, 2003
    5,326
    71
    +58
    Thanks. Transfered it using my memory card. It does work perfectly.
