Using Video Sender Through Panny - Help
Discussion in 'Blu-ray & DVD Players & Recorders' started by daylightfading, Dec 31, 2004.
  1. daylightfading
    daylightfading
    Help please.
    I use a video sender and and have tried the following:
    a) Scart direct into sky works fine.
    b) Scart direct into panny 55 works fine
    My problem is that I only want to transmit from sky to my kids room but no matter how I do it when I change channel on the panny, that channel transmits?
    My set up is sky scart to panny then scart from panny to tv.
    Any Help appreciated.
  2. hao
    hao
    Have you tried a coax from the additional TV connection to your kids room. I have five additional TV sets running from this (via a signal booster) and get all the terrestial channels plus whichever Sky channel is selected. I have the terrestial aerial routed through the Sky box to the DVDR and and then to the screen. It works for me.
  3. johnjackthom
    johnjackthom
    Sep 20, 2001
    707
    46
    Northumberland
    +236
    It may be that you are using the Sky "VCR" scart to the E55. With this setup the E55 can affect what comes out of the Sky box "TV" scart.
    I would try connecting..
    Sky "TV" scart to E55 AV2
    E55 AV1 to Television AV1
    Sky "VCR" scart to Video sender.
  4. daylightfading
    daylightfading
    Thanks. Checked the back of sky and I had the video sender in the wrong socket so all working okay now.
