Using underslung TV speaker as center speaker in surround set-up
Discussion in 'LCD & LED LCD TVs Forum' started by rjknight007, May 19, 2005.
Tags:
  1. rjknight007
    rjknight007
    Dec 13, 2004
    24
    I have a Sharp LC26GA3E television with a speaker hung underneath. In the manual, and on the display menu, it states that this speaker can be used in a surround sound system. On a surround sound receiver, which I am yet to buy, the speakers are attached to the speaker ports - left, right, back left, back right, and center channel. But, the television has an RCA cable center channel connection. Where on the receiver would this therefore connect?
    Many Thanks
  2. jimg
    jimg
    Jul 4, 2004
    826
    +58
    Not sure where the connecter is on thw 26" model, but I would recommend using the centre speaker from your 5.1 system when you buy it. The system's centre speaker will sonically match the others in the system.
  3. Dr Pete
    Dr Pete
    While I haven't done this for my system (Sharp 45"), I believe you'd connect it to the line out for the centre speaker on your amp. i.e. non-amplified output. Most amps have both amplified and non-amplified outputs.
