Question Using svs sb2000 sub with q acoustic 3000i
Discussion in 'Subwoofers' started by lee2007, Jun 8, 2015.
  1. lee2007
    lee2007
    Oct 28, 2008
    233
    +65
    After reading reviews and seeing the speakers i dont want to buy the cinema package and be underwhelmed by the sub so wondered what people thought of swapping it for an svs sb2000 and would it intergrate well?
    Any thoughts cheers Lee
  2. sanjualf
    sanjualf
    Oct 10, 2010
    485
    Eastbourne
    +302
    I think it will work really well. I swapped the sub which came with my monitor audio mass ( which is comparable to the 3000i sub,which was underwhelming) to the SB2000 and it works a treat with my mass satellites. Decent low end, great mid to upper bass and integrate really well. You wouldn't be disappointed.
  3. hifix
    hifix
    Mar 7, 2006
    12,284
    2
    Coventry, West Midlands
    +2,432
    Clean, sealed subs aren't usually too difficult to integrate with most speaker packages. The SB2000 will be an upgrade on most subwoofers that are bundled with 5.1 packages.
  4. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
    yeah you can. Considering the Q Acoustics sub doesn't seem that impressive. Dual 6.5" drivers, 140W amp, ported, probably more midwoofer.
  5. lee2007
    lee2007
    Oct 28, 2008
    233
    +65
    Just wondering where to demo or just order one online?
  6. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
    check who sells them.
    As long as you don't have a large room SB2000 should be plenty.
    I have a SVS SB12+ and SVS SB Ultra 13.
  7. lee2007
    lee2007
    Oct 28, 2008
    233
    +65
    Room is 12ft wide 15ft long with 7 ft ceiling. My kube 2 sub ive just sold sounded meaty enough so im thinking 500watts and 25hz should give me the wack!
  8. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
    music or movies? Or both?
    For that room I'd probably consider the PB2000 if you're into movies (even though I prefer the SB type)
    For music the SB will be plenty.
  9. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
    Or if you're considering duals at some point then I'd choose the SB (since they are smaller) so two SB's wouldn't dominate the room as much as two PB2000.
  10. lee2007
    lee2007
    Oct 28, 2008
    233
    +65
    Bit of both really the kef kube 2 ive just got rid of sounded good 200watts and down to 35hz so sb2000 should have more slam i think!
