Using Sky/VCR and Plasma TV
Discussion in 'Plasma TVs' started by ginga_dj, Jan 13, 2003.
  1. ginga_dj
    ginga_dj
    Jan 12, 2003
    48
    I have a Toshiba 42wp27b coming on thursday (yipee!).
    I have been playing around with the Sky Digibox and the VCR and seeing how I might connect them. At present the VCR is connected to the Digibox and when you play a tape it is routed through the Scart. I tried using the S-video out from the Digibox, but couldnt play the VCR.
    If I connect the Digibox to the plasma using a SCART>VGA cable, will the VCR continue to play as it does now, through the Digibox, or will it not display anything?
  2. jmack
    jmack
    i not sure as the rgb to vga will not do composite on scart (mine wont any way, its proberly working on your normal tv as that will take composite on scart,
    i think thats right but hopefully someone more techie than me will confirm
