Using Sky to distribute DAB
Discussion in 'Music Streamers' started by Billy69, Apr 5, 2005.
  1. Billy69
    Billy69
    Mar 11, 2005
    60
    +7
    OK, a bit of a technical question.
    If I plug a DAB aerial into the aerial in on my Sky+ box, then I run the TV2 output with TVLink turned on to another room, will I be able to separate the DAB and Sky TV outputs after the TVLink magic eye?
    Will I still be able to separate out the DAB and Sky TV outputs if there is a GlobalComm 2-way splitter/amplifier splitting the outgoing TV2 signal?
    Failing that, is it possible to connect a DAB aerial into a cable carrying the TVLink enabled sky output? I was thinking of using a TVLink bridge and a diplexer, with another diplexer after the magic eye?
    Many thanks
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Very doubtful. DAB uses a much lower frequency than terrestrial TV, and it's unlikely that it will pass it through at any reasonable strength.
  3. Boy Lex
    Boy Lex
    How good is your dab signal stregth without the aerial. A few years ago I was doing some mystery shopping as a summer job for digitalone (owners of the commercial national multiplex) and the engineering bods told me that you get more data corruption when the signal strength is at its highest. I've always used the indoor aerial which gets me about half way and the sound is perfect.
  4. Billy69
    Billy69
    Mar 11, 2005
    60
    +7
    My DAB signal strength is OK in most parts of my house using the inbuilt aerial (Its a Pure Bug radio). But unfortunately the room I want it in has poor reception, and I get a lot of drop-outs.
  5. av2diefor
    av2diefor
