Using SKY HD via Component
Discussion in 'Sky Digital TV Forum' started by krsone01634, Jan 3, 2007.
  1. krsone01634
    krsone01634
    Jun 19, 2006
    55
    Chatham, Kent
    Have plugged component cable in for use with SKY HD but getting no sound, any suggestions?
  2. frankie13
    frankie13
    May 14, 2001
    817
    england
    +22
    how about an optical lead to the amp
  3. Rob
    Rob
    Jul 17, 2000
    1,286
    Norwich
    +35
    Which output are you using for sound, optical or phono?
    Presumably you know component is video only ?
    Rob.
  4. krsone01634
    krsone01634
    Jun 19, 2006
    55
    Chatham, Kent
    Did not know it was Video only, will need to use phono leads then, YES?
  5. Brogan
    Brogan
    Oct 9, 2003
    7,582
    Cary, North Carolina
    +482
    Yes, you will need phono leads but be aware you will only get stereo with these.
    If you want 5.1 you will have to use the optical feed.
