Using Sky box & dish as TV aerial??
Discussion in 'Sky Digital TV Forum' started by N11K_DJ, Aug 25, 2005.
  1. N11K_DJ
    N11K_DJ
    Hi, Apologies if the answer to my question is very simple bit i've never had sky installed and know very little about it!
    I've just moved to a new house and there is a newish looking sky dish on the side, the reception from the roof mounted aerial is poor so i'm wondering if i can use the sky dish to recieve my TV signal? ie not subscribing or recieving any sky package, just terrestial TV (& Freeview).
    I've got hold of a black pace skydigibox but it doesnt have a card.
    Any help is much appreciated!
    Nick
  2. Douzeper
    Douzeper
    Aug 22, 2004
    190
    16
    Antrim, Northern Ireland
    You can ring them and ask for a card that only gives you the free channels.
    make sure you have a TV licence:)
  3. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    Bradford, West Yorkshire.
    +324
    Nick,
    A card from www.freesatfromsky.com will give you loads, including the usual terrestrial channels.
    A. Dork
  4. Heinz
    Heinz
    Aug 4, 2005
    408
    Earle Colne, Colchester
    +15
    A Freesat card will cost you £20 BTW.
