Using RGB with AVR300
Discussion in 'AV Receivers & Amplifiers' started by liteswap, Aug 25, 2004.
Tags:
  1. liteswap
    liteswap
    Jun 21, 2004
    336
    East Sussex, UK
    Does anyone here use the HQ Video out connections on their AVR300 to a SCART/RGB-equipped TV? I've tried it and can't get it to work.
    Physical connection is a four-wire RGB+Sync ProfiGold lead to the Panasonic WSTV. Sync is connected to MON out, RGB phonos plug into the colour-coded sockets.
    Software setup has everything set to RGB, yet the screen remains blank. The manual mentions connecting an RGB trigger lead but there's no cable with one of those built-in that I can find. Is this the problem?
    TIA for any assistance.
  2. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    You problem is probably that your TV has not switched to the RGB inputs because it has not recived the RGB status signal. You can either modify your existing RBG lead by adding a stereo mini jack for the RGB and CVBS status lines or purchase one from QED, it is not on their web site but they do have the specification of the cable and can make one for you. The pin out is in the manual if you want to modify your existing cable.
    Regards,
    Andrew
  3. liteswap
    liteswap
    Jun 21, 2004
    336
    East Sussex, UK
    Thanks Andy. I'll have a go at this myself -- I know how to use a soldering iron -- so I need to add an extra lead from pins 8 and 16, that right?
