Using PowerStrip on a laptop
Discussion in 'Desktop & Laptop Computers Forum' started by sraper, Dec 27, 2004.
  1. sraper
    sraper
    Aug 7, 2001
    758
    46
    Watford, UK
    +234
    I have just bought a Toshiba 27WL46 LCD TV and was hoping to use my laptop for playing movies. I have downloaded PowerStrip but I can't work out how to set up a custom res. I believe I need 1280x720. After reading the Release Notes I saw the lines
    The following are NOT supported:
    - ISA and VL-bus graphics cards
    - mobile and integrated graphics controllers
    Is there any hope? The problem seems to be that the "custom timing" button is grayed out on the "Advanced timming options...".
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Only a few chipsets support the custom resolution feature which Powerstrip needs, I suspect if it's greyed out then PStrip has detected your chipset doesn't I fear.
  3. sraper
    sraper
    Aug 7, 2001
    758
    46
    Watford, UK
    +234
    I was really hoping someone wasn't going to say that :(
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Well I don't speak from experience of such a machine, but from using PStrip I think it's a pretty good bet that it's right.
  5. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,146
    41
    NW London
    +17
    install the latest graphics card drivers on your laptop, they should eaily be able to set this custom resolution, forget PStrip for the moment and see how it looks using new drivers that support 1280x720 (Nvidia and ATI's newest drivers are pretty good at this resolution use the appropriate driver of course :p).
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    The graphics drivers will only provide custom resolutions if the chip can support it, and if the chip supported it then Powerstrip would probably have worked in the first place.
