Using PC Speakers (DTT2200) for TV?
Discussion in 'Desktop & Laptop Computers Forum' started by Sicton, Mar 12, 2005.
  1. Sicton
    Sicton
    Jul 26, 2003
    190
    Bristol, UK
    Is it possible to use the Cambridge Soundworks DTT2200 5.1 kit on a TV rather than a PC? I would imagine you would need a converter for the connections because they're split into front, rear and centre/sub.
    Any ideas?
  2. RichIbizaSport
    RichIbizaSport
    Mar 20, 2006
    30
    Hull
    Ive got the exact same speakers and the exact same question!
  3. inzaman
    inzaman
    Dec 16, 2002
    8,018
    Derby
    +1,082
    Moved to hcpc, guys as this is more pc related i will move here to see if anyone else has tried this :)
  4. FeiJi Fancier
    FeiJi Fancier
    Mar 15, 2006
    159
    Plymouth
    +7
    I dont see anything remotely PC orientated about this query - it's a Television to a sound system connection query. No computers involved whatsoever.
    You can certainly connect a TV to a DTT2200 - and it will, if you select the right option, give a pseudo surround sound effect, I would imagine.
    Quite how you connect it, depends on the output options available on the TV.
    A 3.5mm jack headphones socket to the aux input on the DTT2200 will work. Keep the volume control on the PC at a reasonable level - I suggest turning it down to 0 to start with, and gently increasing it until you get a reasonable, unclipped, sound coming from the sound system - set that initially around about volume 5. After all, you don't want to over excite the speakers at this point, you could blow them if the sound level is too high.
