Using normal sky remotes with SKY plus ?
Discussion in 'Sky Digital TV Forum' started by mark.carline, Jun 15, 2004.
  1. mark.carline
    mark.carline
    Jan 15, 2004
    2,133
    Chester, Cheshire
    +121
    I have just had SKY plus installed and I have a second feed from the back of the SKY Plus box (RF2) fed to an extra TV upstairs with one of those remote eye receiver things.
    I dont really want to have to purchase another sky plus remote unless I have to but I just wondered if its possible to use a normal sky remote with sky plus in a remote room ??
    [email protected]
  2. mark.carline
    mark.carline
    Jan 15, 2004
    2,133
    Chester, Cheshire
    +121
    I knew you could do it.......
    To reprogram the sky remote to control the sky+ box.
    The sequence is:
    TV
    Blue+select led flash twice
    2
    Select
    Sky
    Now the sky remote up and down channel buttons change the channels on a sky+ box.
    To revert back, enter this sequence again but press the zero button instead of "2".
  3. mark.carline
    mark.carline
    Jan 15, 2004
    2,133
    Chester, Cheshire
    +121
    If anyones interested this was the link I got this info from:
    http://www.satcure.co.uk/tech/digicode.htm
    I have also used the MACRO button to switch the TV onto channel 6 (SKY) when I press the SKY button.
