Using network cable for phone extension?
Discussion in 'Home Cinema Building DIY' started by nathsea, Jan 29, 2004.
  1. nathsea
    nathsea
    Apr 26, 2003
    917
    +24
    Hi all.....
    Is it possible to use cat5e cable as phone line to run an extension? I have loads of network cable but no phone line cable... Is this OK and will there be any side effects?
    Many Thanks
    Nathan
  2. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    No its fine.
    Try and use the twisted pair rather than splitting them tho. i.e use the blue/ white blue for the line on pins 2 & 5, then anything else for the bell circuit on pin 3, orange usually.
    HTH
    Steve
  3. nathsea
    nathsea
    Apr 26, 2003
    917
    +24
    Steve,
    Wow what a quick reply, thats great news
    Many Thanks
    Nathan
  4. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    no problem. :)
