Using my Wii with Toshiba 36ZP38 TV on component connections
Discussion in 'Nintendo Wii-U & 3DS' started by Sandy 8oy, Dec 19, 2006.
  1. Sandy 8oy
    Sandy 8oy
    Dec 11, 2006
    58
    Hi! I was wondering if any other gamers have used the Wii using the Toshiba 36ZP38 TV using the madcatz component connections setting because im getting a fast flickering effect on mine. Its quite uncomfortable on the eye also. Many thanks
  2. Sandy 8oy
    Sandy 8oy
    Dec 11, 2006
    58
    Anyone?
  3. raigraphixs
    raigraphixs
    Jul 11, 2001
    66,600
    +26,557
    Not sure, do you have a 50/60Hz menu option, try swapping. Also leads in right colours?, tried a different resolution?.
    Anyone else help out?
  4. OCZedd
    OCZedd
    Dec 18, 2006
    64
    9
    Is a CRT then? Will an LCD look better do you think?
  5. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    It is a crt but makes no differece.You should have a good picture.As someone has mentioned try the screen setting on the wii.Also you may have to manually set you tv to progressive scan.
  6. stu.artd
    stu.artd
    Jul 29, 2005
    3,895
    +333
    Have you got the TV set to 100Hz ?
  7. evansma
    evansma
    Dec 19, 2006
    9
    3
    +4
    I get flickering on my Samsung 40" lcd when using the Madcatz component cable. It's ok with the composite cable. I hope the official component cable will fix this, when it finally turns up.
  8. Sandy 8oy
    Sandy 8oy
    Dec 11, 2006
    58
    Its only when i select the hd/edtv option i get this fast flickering screen. maybe i should try it with my 26" Samsung LCD. I dont get this flickering with the interlace options. I have checked my TV and its fine.
  9. lyndley
    lyndley
    Nov 20, 2006
    23
    3
    +5
  10. mwatson800
    mwatson800
    Oct 16, 2002
    361
    Farnborough
    +15
    Stu maybe onto something here! I remember these TV's have various options for processing the image...try different combinations of turning some of them on/off to see if that resolves your problem.
  11. topmba
    topmba
    Feb 13, 2003
    250
    Bedfordshire
    +4
    if you set the wii to 480p (or even 480i*) it should not flicker, as this will be 60hz. PAL progressive flickers.
    *This telly has a built in de-interlacer - set scan to PROGRESSIVE. Then you can use RGB to the same effect. I use my component for the PROGESSIVE DVD player - it overruns the scan option - it stops it showing on the TV MENU. I wish it had 2 component inputs.
