Using my TFT speakers..how?
Discussion in 'Cables & Switches' started by Ready 03, May 8, 2007.
  1. Ready 03
    Ready 03
    Just got my new TFT monitor...Sony SDM-HX73.....how can i use the speakers on the monitor, i have cheap acer speakers on the side but im thinking the sony one will be better, what cable do i need? the monitor has 3 sockets, 2 hd15 and 1 dvi-d.....at each one is a small jack socket....do i go buy a audio cable with the same sockets at each end and plug it in a into my pc where my speakers are already?
    thanks for any help you can provide...:smashin:
  2. Gregory
    Gregory
    Mar 27, 2005
    312
    Midlands
    +9
    Sounds likely. You might want to check if the speakers have an amp (or need one) though. Best bet for a safe trial would be to try straight from the line out on the PC to the socket on the monitor. I wouldn't bet on then being great though BTW.
