Question Using multiple outputs at the same time to 2 separate amps.
Hjm80
Can I connect my squeezebox touch to 2 separate amps at the same time using different outputs and will they play simultaneously one being at stereo amp and one being a av amp for a large room.
Many thanks
Hywel
RBZ5416
Yes, all the SB outputs are live simultaneously.
Whether they would be perfectly in sync is impossible to predict as there could be delays introduced by the AVR's DAC.
