using MCE with dvb-s without a sky package.
JonLeach
Established Member
Joined
Sep 17, 2002
Messages
756
Reaction score
22
Points
206
Age
Location
Deepest Darkest Yorkshire
i have read through the thread about using mce with sky and ok great if you have sky,
i'm after not using sky but would love to have access to these bbc-hd channels or any other for that matter.
i'm too far away from Crystal Palace, 200 miles!! to use freeview so whats the alternative? if there is one.
Jon
The description in the Sticky can be used to set up MCE with all the Free To Air DVB-S channels much more simply than worrying about the encrypted channels.
It's not possible to integrate BBC HD satellite TV into MCE but the excellent DVBViewer can be used for viewing & recording all the SD FTA channels as well as BBC HD. It can even be set up in server mode so that other DVBViewer clients on the LAN can watch satellite TV too. You can even watch & record several channels at once with just one satellite card provided that they ar all on the same transponder e.g. BBC HD plus BBC 1 or BBC1+BBC2+BBC Three+BBC Four
There is a plugin application for Digigide called DABdig that apparently allows you to schedule recordings from Digiguide.
cheers nigel more digging required
Jon
I should also add that the picture quality from even SD channels using a DVB-S card is by far the best that is obtainable. Much clearer than RGB from a digibox & about double the bit rate of DVB-T (Freeview).
RESTORATION vs. REVISIONISM: At what point do 4K video and audio 'upgrades' cross the line?
Back
