Using Marantz remote to control NTL
StevieDvd
Joined
Dec 27, 2003
Messages
1,378
Reaction score
151
Points
299
Age
68
Location
Stevenage, Herts
Has anyone managed to find the correct code to enable the Marantz 5400 Remote to change channels on the NTL Pace DI4001 box (one with blue remote that uses standard remote signals).
All I want is to be able to change the channel up/down or number.
Steve
The Pace Cable boxes use IRDA infrared (like PC's and mobile phones), standard remote controls don't. It won't be possible to use a standard system remote to control the cable box, but it is possible to use an adaptor attached to the box, I believe they're called a Red-Eye.
Originally posted by hornydragon
Pace 4000 doesnt USE IrDa so Marantz should learn it, My RC1200 did!
My bad!
In which case can someone point me in the direction of the code for my Sony STR-DB790 remote?
The remote with the SR5400 does not have learning capability and I have tried the scan code option without much success. The best it does is to send '8' when the power off button is used.
I know it uses standard remote codes as I was able to program a OneForAll remote to reproduce the NTL remote buttons.
But the Marantz needs a 4 digit RC5 code (I think that's what it's called).
StormAudio ISR Fusion 20 AV Receiver - review coming soon #HomeCinema #Amplifier #VideoShort
Back
