Using LCD with a laptop
Discussion in 'LCD & LED LCD TVs' started by vernall, Aug 16, 2005.
  1. vernall
    vernall
    Nov 28, 2003
    534
    Worcester
    +22
    Hey guys
    wonder if someone can help me please?
    Im after buying a 32" LCD TV,the model I'm after has a DVI-I socket on it(NO VGA),which can be used for HDTV(when it arrives,or so im told) and also to use the screen as a PC monitor......I have a laptop,the laptop only has a VGA socket on it,can I connect the 2 via this method?so it will be VGA to DVI and is it a case of just plugging one end into lappy,other into LCD and select PC on LCD remote or is there more to it than that?
    also any tips on where to get such a lead/adapter too please
    thanks guys
  2. daxie
    daxie
    Jul 9, 2005
    242
    16
    Just don't buy that LCD...
    It has 0 of the connections you need now, and you need in the future
    now:
    VGA => lacking, which is present at about every other set
    future:
    HDMI
    DVI-I is only a step in between, and is kept in order to be compatible with current appliances, but will be replaced by hdmi in the future
