Using just a TV as a display
Discussion in 'Desktop & Laptop Computers Forum' started by annefromuk, Mar 27, 2003.
  1. annefromuk
    annefromuk
    I was thinking of buying a new Small Form Factor PC, minus a Monitor, and then linking it to a TV.
    Does anyone have any experience of this?, and would the PC be useable this way?
    Also, as I will be buying the TV around the same time, is there any recomendations for any particular make/model that can be used in this way?
    Regards
    Anne
  2. mephistopheles
    mephistopheles
    The short answer is no, not really. There have been more than a couple of threads on outputting to TV from PC very recently. Try a forum search and you'll see that it's probably OKish for non-text stuff. The 2 are just not compatible.
    If it's an HCPC you're getting, or you already have one, why bother with a TV at all? For the cost of a new TV you could get yourself a very large monitor, and use that for both PC and home cinema, and still have change after buying a new PC, too.
    I found myself in a similar position a short while ago and couldn't stretch to a plasma (or even a new w/s TV come to that!) so I eventually decided on a 1986 37" 4:3 multisync CRT monitor with remote control for £400 on eBay. You can get them for considerably less, but mine was in superb condition. I heard of one for £200 a few weeks ago from a dealer.
    I get absolutely incredible TV with DScaler, DVD etc etc and the XP desktop is crystal clear at 1152x864 from the other side of the room. I can also use a direct connection from digital cable box/DVD player etc etc via either composite video, s-video or RGB if I need to and use the monitor's onboard stereo.
    For me this is the ideal limited budget setup.
