Using iPhone 3G as laptop modem !
Discussion in 'iPhone Forum' started by judethedude, Jan 29, 2009.
Tags:
  1. judethedude
    judethedude
    Oct 6, 2005
    2,917
    Lancaster
    +179
    Is there a way of using the iPhone 3G as a modem for a laptop in order to access the internet ?
    Thankyou
  2. Jase Winter
    Jase Winter
    Sep 1, 2007
    5,378
    103
    Tadley
    +416
    Yes you need a jailbroken iphone and the pdanet application (from cydia), works very well and now supports USB connection rather than having to use a wifi ad hoc network.
  3. judethedude
    judethedude
    Oct 6, 2005
    2,917
    Lancaster
    +179
    Thanks for the post Jase Winter.
    Is it just a case of installing the pdanet application and then connecting the laptop to the iPhone using the standard iPhone USB connector or will I need to install software onto the laptop ?
    Thanks again :thumbsup:
  4. Jase Winter
    Jase Winter
    Sep 1, 2007
    5,378
    103
    Tadley
    +416
  5. judethedude
    judethedude
    Oct 6, 2005
    2,917
    Lancaster
    +179
    Excellent info Jase Winter.
    Laptop now synched with iPhone and browsing the Net !
    Thank You :smashin:
  6. Jase Winter
    Jase Winter
    Sep 1, 2007
    5,378
    103
    Tadley
    +416
    No problem mate, it's a great app, its free for 14 days then you have to pay for the full version, however, I never upgraded and find the free version works fine for the kinda browsing I do (mainly on here and online dvd shops!).
  7. gkf9
    gkf9
    Jul 29, 2006
    4,976
    +2,399
    No Usb connection for Mac..... Bugger!
  8. bigdavecox90
    bigdavecox90
    May 27, 2006
    2,948
    71
    +53
    I take it this just uses your iPhone's unlimited internet, rather than extra costs incurred?
  9. judethedude
    judethedude
    Oct 6, 2005
    2,917
    Lancaster
    +179
    As far as you mobile network is concerned your browsing the internet with your iPhone so yes, the data used will be part of your inclusive allowance.
  10. bigdavecox90
    bigdavecox90
    May 27, 2006
    2,948
    71
    +53
    Yeah, so with the default O2 tariffs it would be all included.
  11. Jase Winter
    Jase Winter
    Sep 1, 2007
    5,378
    103
    Tadley
    +416
    Yeah I have been using this for a while now on my o2 tarrif and have incurred no further costs.
  12. gwop
    gwop
    Feb 1, 2009
    jailbreak and use pda.net
    if you add the xsellize repo you can get a "unlimited version"
    Just create ad-hoc network and conect via that way
    All i need now is a way to spoof my iphone MAC address on my netbook so i can use cloud or openzone
    on my netbook
    I use leo 10.5.6 aand nothing works.
  13. halfords
    halfords
    Feb 11, 2009
    4
    I am getting a netbook with 3g modem built in can i take out my iphone sim and use in netbook?
  14. Red_Stafford
    Red_Stafford
    Dec 28, 2007
    212
    Dudley, West Midlands, UK
    +3
    is there a way of connecting your Xbox360 online through your iPhone using this software ?
  15. WATTS
    WATTS
    Mar 16, 2007
    863
    Black Ops
    +50
    Im pretty sure the LAG would be horrible... :thumbsdow
  16. RuddyRoad
    RuddyRoad
    Dec 8, 2004
    3,492
    Edinburgh
    +1,445
    Actually, funny thought this sounds, I used to play my brother at Burnout Paradise and Resistaance 2 on PSN. Although I have landline broadband, he had a mobile broadband dongle and it worked a treat. The datastream of the 3G network in some instances is faster than some people's home broadband.
