Using IPAQ as remote control
Discussion in 'Home Cinema Control & Remote Controls' started by Noel, Sep 25, 2003.
  1. Noel
    Noel
    Dec 18, 2000
    420
    +8
    Hi Guys,
    Haven't posted for a while and I'm getting a little confused. Perhaps you can help?
    I have an IPAQ 3630 which doesn't get much use. I noticed that PDAs can be used as universal remotes so I've done a bit of searching around and have come up with the following:
    1) It looks like I need to buy the TV remote control software from PDAWIN. This seems to be popular and it can work with CCF files (I have a pronto and can just about use ProntoEdit!). This software can be downloaded for $14.95.
    2) Then I may need the PDA-IR extender (if the range is poor without it) which seems to be available for around £25. Laser.com have a notice stating it's out of stock and when I phoned them I got the "no-one available to take your call" answering machine. Are Laser.com still around or does anywhere else stock these?
    3) I don't have a CF jacket for my IPAQ and these seem to be around £80. Is this about the right price? It appears that this comes with an additional battery which will help. Will this also let me view photos from my digital camera (which has a CF card) or will I need additional software?
    I think that's it. Sorry it got a bit wordy, thanks for your help in advance.
    Noel
  2. DaveP
    DaveP
    You can download a 30 day trial version of the software from PDAWin. If you've used Prontoedit does this mean you have a Pronto? If so you may as well continue to use that as the PDAWin is just a pronto emulator!
    I used it for the trial and the IR worked ok on my tele at a distance of about 8 feet but you have to point it at the box. This can be difficult if you are a "laid back" viewer!
    You cannot see the screen at the same time to touch the correct button.
    You shouldn't need additional software to view images.
    Dave
  3. Noel
    Noel
    Dec 18, 2000
    420
    +8
    Thanks for the quick response Dave. Yes, I have a Pronto but was thinking of buying another (or a Pro) for another room. This way it appears I get to cheat a bit! Does the plan make sense?
    Cheers,
    Noel
  4. DaveP
    DaveP
    Yes it's a cunning plan!
    Try the evaluation copy and see how it goes. You just use the config file from your Pronto and away you go!
    Let me know what you think!
    Dave
  5. Noel
    Noel
    Dec 18, 2000
    420
    +8
    Thanks Dave. I downloaded the trial (subseqently activated) version last night and uploaded a Pronto Pro CCF from Remote Central. Tweaked around with it a bit, and it's good. The range is quite poor, but I guess the CF jacket and IR extender will sort that out?
    Is there any news on when the IR extender might be available? (Reading another thread it seems there are some probs with this).
    Thanks again for your help, I have a feeling this could work out quite well.
    Cheers,
    Noel
  6. Sandman
    Sandman
    Nov 28, 2002
    3,187
    Glasgow
    +730
    The manufacturer of the ir extender has stopped production on it. I think laser are buying the rights to manufacture this but it could be some time before we see it.
    There is another ir extender available but I have forgotten the name of it. I will get back to you soon.
  7. Sandman
    Sandman
    Nov 28, 2002
    3,187
    Glasgow
    +730
    UltraMote Extender, you will need to buy their software before they will sell you the extender but it is not too expensive.
  8. Noel
    Noel
    Dec 18, 2000
    420
    +8
    Thanks Sandman. Is it a CF extender as it looks like that's the only way I can connect?
    Cheers,
    Noel
  9. Sandman
    Sandman
    Nov 28, 2002
    3,187
    Glasgow
    +730
  10. Noel
    Noel
    Dec 18, 2000
    420
    +8
    Thanks Sandman.
  11. gaz.thomas
    gaz.thomas
    Dec 17, 2002
    58
    Worcestershire
    I use the ultramote cf extender with pdawin remote control on my ipaq 3630 and have had no problems whatsoever. Range and off-axis performance is excellent and the docking station acts as a stylish desktop charger.
    Gaz
    -x-
  12. Noel
    Noel
    Dec 18, 2000
    420
    +8
    Thanks for the responses guys. I have been playing around over the weekend and the remote seems to work OK just using the PDAWin software. I have to point the Ipaq more or less straight at the equipment, but it works on the first press from around 10 feet away for all my kit.
    Looks like I have been lucky!
    :D
    Thanks again.
