Question Using installed co axial to Ethernet
Justanothersept
Hi all,
Complete newbie here but nowhere that I can find advice.
Basically my house is about 6 years old 3 story house, I want to run a few Ethernet wires around the house cause WiFi & powerline just not hacking it. I have co-axial points in the wall throughout the house but I don’t use them for tv signal at all. So is there a way of connecting a fish wire through with the co axial wire from the attic to the access point downstairs then pull through the Ethernet wires ?
Any help would be great thanks
mushii
It is unlikely as it will either be run under capping or clipped in place. If you are going to do this, do it properly and chase and fill. I did this on my 3 storey as my cinema room is on my top floor. It took me a couple of days to work out routing then another day to install and another day to patch, fill, sand and paint.
I ran a pair of cat 6 from my comms cab on the ground floor Switch to my top floor Switch then bound them in a 2 Gb LAG. I also installed a Ubiquiti AP on every landing for WiFi
