Using in built mic in macbook inside VMware Fusion
Discussion in 'Apple Forum' started by fizl, Jan 12, 2008.
  1. fizl
    fizl
    Apr 21, 2006
    2,164
    Not in London
    +460
    Hi everyone
    I have VMware Fusion running windows XP, which I use to run Rosetta stone. One of the exercises it uses is to record your voice so you can compare the speech pattern.
    I don't know how to get the mic working inside VMware fusion so that I can do this stuff, as it just says sound will not be available (for the mic).
    Sound output is fine, its only getting it in that I have a problem with.
    Anyone have any ideas? (Its one of the new macbooks, bought just before Xmas)
    thanks
    shaz
  2. jms_uk
    jms_uk
    Jan 10, 2006
    1,491
    Guildford
    +200
    You should be able to get the BootCamp drivers for the various Mac devices.. and you can use them to install the devices you need - I got the iSight drivers off of the 'net and installed that no problem! Wasn't sure if I was able to use the drivers directly off of the BootCamp CD that OS X lets you create though..
    Hope this helps :)
  3. fizl
    fizl
    Apr 21, 2006
    2,164
    Not in London
    +460
    Thanks for the starter.
    I'm a mac newbie, so could you give me a bit more info on what to do please?
    thanks
    Shaz
  4. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    42,276
    11
    13
    167
    ::1/128
    +15,653
    And I thought that the Rosetta stone discs came with both PC and MAC versions. They've definitely got a Mac version so I would contact them if you have not got it on your disc.....Easier than using emulation....
