using ICE ideas in home cinema
Discussion in 'Home Cinema Speakers' started by adi, Mar 15, 2003.
  1. adi
    adi
    look through modified car mags and all the music installs consist of multiple speaker arrays (woofers, mids and tweeters), driven by separate amps, specifically positioned to give the best sound projection in the available space all backed up by huge ported subs housed in enclosures tailored to cone size and amount of air needing to be moved.
    given enough money - would it be feasable to do this in a home cinema setup - individual drive units in separate enclosures positioned exactly where necessary to give the best sound in a specific location
    if so - how the hell would you go about sending the necessary signals to the relevant areas
    or have i just drunk too much caffreys ???
    adi
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Seems perfectly reasonable.
    I currently working on a sub with Taz that uses a JL 10W3 D4 driver designed for use in small enclosures in cars It's more than capable of shifting air in the home scenario though.
    Bear in mind that in car speakers are designed with in-car acoustics in mind though, you may need to do some tweaking (usually available on in-car systems) to tailor the sound to suit your home scenario.
  3. shodan
    shodan
    Dec 11, 2001
    11,590
    shoeburyness
    +6,504
    Seems feasable to me. I had just enough money to drink this much lager in a home cinema room....
    :clap: :clap: :clap:
  4. adi
    adi
    how would you "tweak" it to suit ???
    imagine a typical HC speaker consists of a woofer, a mid and a tweeter.
    In a 5.1 setup you would potentially have 15 separate drivers (plus sub(s))
    ideally, each element of each speaker would need to be positioned separatley to ensure accurate sound placement - how would you actually drive them ???...... a typical 5.1 receiver with "tri-wiring" from each channel, or a separate power amp for each driver driven by a pre-amp
    (imagine how complex that would need to be)
    adi
  5. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    You can buy active speakers which are close to what you are looking for (active x-over and seperate amps for the bass & mid/highs).
  6. adi
    adi
    thats only partly what i'm getting at........in ICE applicatons, each driver is positioned specifically where it is needed, so the entire spave is filled with sound where needed - te active speakers you mention would overcome the possible problems with powering the system, but not the positioning.
    instead of 1 box with 3 cones in the front - you'd need 3 separate boxes - 1 containing the tweeter, 1 containing the mid and 1 containing the woofer
    the only comparable thing ive seen is the high end installations which heve in-wall and in-ceiling speakers, but even this would seem to be a compromise
    are any of the installation guys looking at this - if so - what do you think ???
    adi
  7. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Excuse my impudence..... but every car system I have ever heard makes me want to keep my hifi and cinema system as far to the other end of the scale as possible! So what am i missing here!?
    ad
