Using HTPC with Sony VW10HT
Discussion in 'Desktop & Laptop Computers Forum' started by NedK, Jun 12, 2002.
  1. NedK
    NedK
    Jun 5, 2002
    49
    Fleet, Hants
    +3
    Hello all,
    I've been experimenting with my PC and the VW10 to see if it's worth building a proper HTPC. I used powerstrip to set the HDTV "emulation" resolution, and PowerDVD 4 in full screen mode. The output on the screen comes out smaller than the full panel size, so there is a light border around the picture.
    Is there a way to get the VW10 to scale up to the full size? It doesn't seem to allow me to change to "full" mode, so is this the best I can hope for?
    Rob
  2. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    In Powerstrip there is a resolution which is something like 1183x666. Apparently this is the one that works best on the 10HT.
  3. NedK
    NedK
    Jun 5, 2002
    49
    Fleet, Hants
    +3
    Yes, that's the resolution I was using. But even on full screen mode it doesn't use the whole panel. I just find the light borders somewhat distracting as they illuminate the walls to the side of my screen.
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,055
    I think the only way you're going to be able to do this is to put powerstrip to a setting like 1280 x 720P at 60Hz HDTV and muck around with the sync settings to get it to lock on. The Sony will then use it's own scaler to make the thing fit the panel but you should get a superiour picture to just going straight in from a DVD.
    Gordon
  5. minimivic
    minimivic
    Mar 28, 2001
    230
    Shaftesbury, Dorset
    +16
    1184 x 666 is the correct resolution you will need a VGA to 5 phono cable, and set the projector to DTR ( cant remember ) but not computer. It should work fine and give good results.
    Use the 16:9 LCD 1184x666 resolution in powerstrip.
