Using Htpc to scale up video image.
Discussion in 'Projectors, Screens & Video Processors' started by condor, May 1, 2005.
  1. condor
    condor
    Apr 14, 2005
    59
    Hi there all, managed to get my Barco graphics 808 up and running I am using powerstrip to manage setting and dvds look great. The problem I am having is I dont know what software to use to input and scale up my vhs as line doubling is not really good enough. I can input svhs into my htpc I have a ati 9800 card which accepts svhs input, however I just dont know what software to use to view and scale up the image, any suggestions? Thanks for viewing especially if you can help.
  2. Welwynnick
    Welwynnick
    Mar 16, 2005
    7,187
    Welwyn, Herts
    +866
    Condor, do you mean s-video (little din-plug thing with separate chroma & luma) or s-vhs (high(ish) band vhs tape)?
  3. GagHalfrunt
    GagHalfrunt
    Sep 1, 2001
    527
    North Cotswolds
    +3
    I would personally use DScaler . However I'm not sure if will work with your card but the DirectShow filter might.
  4. flibble
    flibble
    Feb 21, 2003
    72
    Condor, if you have an ATI card with video in, there should be a program called 'TV' which is bundled with the 'Control Panel' software for ATI cards. Use that, go 'full screen', job done :) [1].
    Peter
    [1] It's been about a year since I had a Radeon with TV in, so this is all a bit foggy.
  5. flibble
    flibble
    Feb 21, 2003
    72
    Ack, not 'Control panel', it's bundled with 'MMC' (Multi Media Centre), I told you I was a bit foggy :)
  6. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    Best off buying a £30 phillips chip TV card and using D-Scaler, the best money you'll ever spend on your setup!
  7. surrey lad
    surrey lad
    Dec 14, 2002
    718
    Kingswood, Surrey
    +29
    What you need is my Holo3Dgraph-1 rev7 card that I'm selling in the Classifieds Section !!!!!!! :D :devil:
