Using HDD greater than 32GB
Discussion in 'Computer Components' started by Messiah, Dec 26, 2003.
  1. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Despite the fact that both my PCs use 250GB discs I have just resurrected an old PIII 500 and set it up as an upgrade for my mothers PC. Believe it or not her old machine had just 2.6GB HDD in it :eek:
    I have fitted a 60GB drive in the PIII 500 PC but the BIOS is obviously old and it will only recognise the disc if I set the jumper to limit it to 32GB.
    Does anyone know of any software that will enable the PC to see the full 60GB? I tried installing the Seagate OnTrack program but it simply caused the PC to request to boot from floppy every time it was switched on. What's strange is I know I used to use that PC (a few years back now) with larger discs but again must have used software to get over the size limit. New HDD, no software so anyone got any suggestions?
    Thanks.
  2. Majik
    Majik
    Jun 10, 2003
    193
    Coventry
    BIOS upgrade my friend.
    Majik
  3. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Thanks. I was hoping not to have to go down that road. Think I'll just leave it as using the 32GB as that's way more than she's likely to need and then just upgrade her to a new machine in 12 months or so.
    Thanks again.
  4. scooby do
    scooby do
    Dec 11, 2002
    2,023
    48
    +88
    Correct me if I am wrong but why not partition the drive using FDISK then hopefully windows will see it as two 30 GB partitions
  5. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Unfortunately, if I remove the 32GB limit jumper the BIOS does not even recognise the disc so don't think it would work.
  6. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    Before windows can see the disk, the bios has to see it. I have a 120gig disc on mine split into 3 partitions but it is still reported as 120gig in the bios at start up.
    At least you have an option, my oldest machine will not see a disc over about 20gig, and there is no option to make it see a smaller one.
