Using HCPC for Euro1080 on Pioneer Plasma
Discussion in 'Plasma TVs Forum' started by rombrero, Jul 8, 2004.
  1. rombrero
    rombrero
    I want to use a HCPC (HTPC) to receive Euro1080 on my Pioneer 433MXE
    For DVD watching it is possible to compensate for rectangular pixels with software like Zoomplayer and TheaterTek
    How do you compensate for rectangular pixels when you want to watch
    euro1080 (HDTV) or standard tv with DVB-S software
    Is there a solution to deal with this problem or may be there is dvb-s software that allows for compensation for retangular pixels.
    In there someone out there who uses his pioneer plasma display to watch satellite tv with help of a HCPC with succes
  2. rombrero
    rombrero
    Can i use Dscaler for this and if so does someone know how this will work
    (for instance what kind of settings)
  3. rombrero
    rombrero
    Can nobody help me ?
  4. Eagerbeaver
    Eagerbeaver
    Looks like nobody has done this before
  5. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    Try the home theatre PC forum mate...
  6. rombrero
    rombrero
    Did try the HCPC forum. Nobody knows it over there either !
    Can not imagine that i am the only one who would like to use a HTPC
    for watching HDTV
  7. NonPayingMember
    NonPayingMember
    Oct 18, 2002
    8,523
    Kent
    +830
    I don't think it's a case your the only person that would like to do it, it's just a case that no-one's tried it yet!! I know it's obvious but perhaps you could contact the manufacturers of the software you have mentioned? I would certainly contact dscaler since i'm sure it could be configued by dscaler for a HDTV card much the same as it can for a standard tuner or input card.
  8. rombrero
    rombrero
    I have read that dscaler doesn't work with digital signals, it can only handle analog video.
    Ofcourse i want to take the digital route. Going digital (from the sat-dish) in to the HTPC with wintv nova (sat. tuner card) and than go digital through ati radeon with dvi to the dvi input of the plasma (using the native resolution of the screen,dot by dot)
    I had the impression that Dscaler could do something with the digital signal from the sat-tuner card( wintv nova) and than correct the aspect ratio
    Appearently there no solution for "rectangular pixels issue" if you want to use your HTPC as a sat-tuner and in the same time want to take the "complete digital route"
    May be the only way is to choose a different resoltion than the native one (1024x768) and let the plasma do the scaling
  9. Rob
    Rob
    Jul 17, 2000
    1,285
    Norwich
    +33
    Dscaler will work with digital signals. My HCPC has a PMS SDI card which I use with a modded Denon 3300 using Dscaler to deinterlace. Works a treat.
    Rob.
  10. rombrero
    rombrero
    This is all very confusing. Appearantly Dscaler can grab the signal
    from a PMS SDI card and scale (or alter the aspect ratio) it, but the programme can't scale it (or alter the aspect ratio) if you are using a digitalsat-card like wintv nova.
    May be someone can give some insight in to what kind of hardware Dscaler is compatible with
  11. Rob
    Rob
    Jul 17, 2000
    1,285
    Norwich
    +33
    Dscaler (as far as I know) will work with whatever signal you send it SDI, Component or whatever. It is then passed to the graphics card for scaling.The control of the graphics card is done by using Powerstrip. You can dial in whatever resolution, refresh rate and other timing parameters you require. Its certainly a very comprehensive piece of software.
    Rob.
  12. rombrero
    rombrero
    Hello Rob,
    Unfortunately Dscaler doesn't support DVB-s (satellite) cards. I have read that you can use the Dscaler filters in ffdshow but i don't know if the aspect ratio can be altered in such a set up
  13. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    I should think trying the HDTV forum is the place, or try the builders of HCPC's like UVEM etc. I have no experience of this either, but have used freeview cards with this exact setup, it's certainly possible to do what you need with that, I see no good reason why it shouldn't be done somehow with HDTV
