Using FlashFXP to connect PC to XBOX
Discussion in 'Xbox Forums' started by dUnKle, Sep 2, 2004.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    13,632
    +1,462
    I used to be able to do it fine but since a new PC I can no longer do it
    I open up FlashFXP
    Go to the sites part
    Enter the IP address of XBOX
    Enter Password and Name of XBOX
    Click Connect
    And nothing happens
    Just will not connect
    Any ideas how to fix
  2. broona
    broona
    Aug 26, 2004
    5,412
    Hexham
    +547
    I've just started using Filezilla instead, works much better than FlashFXP, as I ALWAYS had problems connecting with that.
    There are also some good guides over at Xbox-Scene Hope this helps. :)
  3. buzlightyear
    buzlightyear
    Oct 8, 2002
    945
    46
    London
    +116
    you must make sure that your pc is on before your Xbox (into OS). Then turn your Xbox on. At least i think its that way round, ive not done it for ages :rolleyes:
  4. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
    why not just use windows explorer to do it, its pretty bare bones, but it can do most things that youd want to anyways.
    theres an article over at xbox-scene about it
    (link above)
  5. dUnKle
    dUnKle
    Jan 1, 2001
    13,632
    +1,462
    Well no matter what I try - FlashFXP - Filezilla or WinXP I can not connect :(
  6. kelvin
    kelvin
    Apr 22, 2002
    1,544
    Down South... (Bournemouth)
    +45
    Have you set up the network properties of your PC correctly?
    A great tutorial on networking your Xbox can be found here - I'd go through it, checking all of your settings along the way (xbox & PC) just to make sure it's not a setup issue.
    K.
  7. rahulkohli
    rahulkohli
    make sure all firewall or anti virus software are off or configured correctly. also make sure your network card is turned on, and configured.
  8. dUnKle
    dUnKle
    Jan 1, 2001
    13,632
    +1,462
    As far as I can tell everything is fine and nothing has changed
    I have my PC and my XBOX connected to a dlink router
    The XBOX can access LIVE and the PC can access the net it just looks like they do not want to talk to each other any more
  9. Daithi
    Daithi
    Feb 12, 2003
    77
    Dublin
    Do you need to specify a port number maybe?
