Using External HDD with Foxsat HDR
Discussion in 'Satellite TV, Sky TV & FreeSat' started by rolandh, Feb 20, 2014.
Tags:
  1. rolandh
    rolandh
    Nov 22, 2011
    141
    +4
    I've got an external HDD plugged into the rear USB port of my G1 Humax Foxsat-HDR, I copied some recordings from the internal 500GB HDD to free up some HDD space, but I've come across a problem when it comes to deleting a recording from the external HDD I get a message saying Can not delete due to file restrictions.
    My external HDD is formatted in EXT3 and the recording that's giving me problems is the Titanic Documentary that was on Channel 5 + 24 on Friday.
    Has anyone got a solution to this problem?
    Roland
  2. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,544
    Redditch
    +4,187
    Have you accidentally protected the recording ? With the file highlighted the blue button toggles lock/unlock
  3. rolandh
    rolandh
    Nov 22, 2011
    141
    +4
    I've used the OPT+ menu to lock/unlock & protect/unprotect and still get the same issue.
    Roland
  4. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,544
    Redditch
    +4,187
    Run out of ideas. You may have to use a PC booted into Linux to delete the files.
  5. rolandh
    rolandh
    Nov 22, 2011
    141
    +4
    It looks like I'm going to have to dig out a Ubuntu CD to delete it then.
    I used a Windows Partition manager Program that can Format to EXT3 as I couldn't find a Ubuntu CD as the flat is in a mess from moving in, could using a Windows Program to format an HDD to EXT3 be the root of the problem?
    Roland
  6. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,544
    Redditch
    +4,187
    I wouldn't have thought so as the Foxsat worked with it.
    You can download a new Ubuntu boot disc image.
  7. rolandh
    rolandh
    Nov 22, 2011
    141
    +4
    I might give booting to Ubuntu to delete a go now that I've found my Ubuntu Disks.
    Roland
