yasmatazz
Established Member
Hi all
Apologies I'm not very AV literate and am hoping one of you very kind people will be able to help me. I have a very old Philips LCD TV (model 42PF5421) that I bought in 2007 which I wish to replace with a Samsung UE48JU6400. My existing TV is wall mounted above the fire place and has the bracket connected like so:
Side view
Wall bracket
The question I have is would I be able to unscrew the fittings from my existing TV and screw it onto the Samsung? If not can I replace just the TV side bracket without having to touch the part bolted on the wall?
I'm not a very confident DIY'er so would rather not replace the entire bracket set including what has been fitted to the wall if possible.
Any feedback greatly appreciated!
Side view
Wall bracket
