Using DVD Decypter for ripping DVDs for PSP - help needed
Discussion in 'Playstation Forums' started by figoagogo, Jul 10, 2005.
  1. figoagogo
    figoagogo
    Mar 29, 2005
    8,162
    +584
    I have PSP Video 9, which seems to work quite well - although a "fit to memory stick" option would be great! I am used to ripping DVDs with DVD Shrink as it is quick and simple. I am now trying to use DVD Decrypter and there are so many options! My questions is - how can I use DVD Decrypter to Rip individual chapters from a DVD. i.e. I am trying to extract the individual short films from the Animatrix DVD, I want each short on its own so I can fit what I like a good quality on my Memory Stick, I will also like to do the same with the Clone Wars.
    Any ideas....?
  2. jerkyboy
    jerkyboy
  3. figoagogo
    figoagogo
    Mar 29, 2005
    8,162
    +584
    Thanks for this, I will give it ago later - as I thought its not as straight foward as I hoped, but if I take my time I should get what I want.
    Cheer-me-do
  4. jerkyboy
    jerkyboy
    Its not as bad as it looks. Once you get it all set up its pretty straight forward.
  5. figoagogo
    figoagogo
    Mar 29, 2005
    8,162
    +584
    Well it worked, I wont be doing often as it take me too much time and I'm inpatient!
    PSP Video 9 crashed several time also :(
  6. chrislad
    chrislad
    May 6, 2005
    5,642
    83
    Rep. of Ireland
    +141
    Really? Never happened for me. PSP Video 9 is great, other than the fact that it gives me an error every time it tries to create a .thm file, but since I don't use them, that's not really a problem.
