Using DV camcorder as digitiser
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by chrisberry, Sep 23, 2005.
  1. chrisberry
    chrisberry
    Can I use my Panasonic NVGS250 camcorder as a digitiser, to record from a VHS through the camera to my ibook? I don't wnat to record to the camera, but directly to my hard drive.
  2. laser
    laser
    Aug 1, 2004
    986
    Hartlepool
    +45
    I think you'll have to record to the mini dv tape and then ouput to the ibook. I'm not familiar with the GS250 but I don't think many camcorders have a loop through facility.
  3. melliott1963
    melliott1963
    Nov 27, 2001
    427
    Ilford, Essex
    +4
    I can do this using my Sony TRV33.
    I don't know your particular camcorder, but does it have AV-in? If it doesn't (a lot don't) then you definitely won't be able to do this.
    Why don't you just try it (or have you already tried and failed)?
    The other thing to ensure is that you use the correct AV lead. The ones that are supplied with camcorders are usually output only i.e. from camcorder to VHS. You need to make sure that you've got a lead that will work in the other direction. I personally use a switchable lead that I purchased from Maplin.
    ***EDIT***
    ooops, did see you'd double posted!
