Using DAP in the car
Discussion in 'Headphones, Earphones & Portable Music' started by dq1967, Aug 22, 2005.
  1. dq1967
    dq1967
    Mar 14, 2004
    30
    Right, now I've got the HD5H, ripped all the cd's and played with it, I want to listen in the car. I've bought a Goodmans cassette adaptor which is OK , but a bit low level in my car's cassette deck, leading to hiss from the car hifi on quieter trax, cos I have to pump it up.
    Does anyone have a good recce for either a different cassette adaptor, or even a good FM transmitter. I've got a Peugeot 307SW with a Peugeot badged head unit (think it's either Clarion or Blaupunkt), any help much appreciated.
    thanx,
    Dq
  2. HMHB
    HMHB
    Nov 11, 2001
    25,517
    Nottinghamshire
    +3,852
    Have you applied the volume unlocking fix to your HD5 ? If not have a look in the FAQ sticky at the top of this forum
  3. myepitome
    myepitome
    And have you changed the setting from headphones to line out?
  4. KiNeL
    KiNeL
    Aug 18, 2005
    333
    Essex
    +7
  5. KiNeL
    KiNeL
    Aug 18, 2005
    333
    Essex
    +7
  6. OneMoreSolo
    OneMoreSolo
    Mar 17, 2005
    852
    28
    +47
    I bought a new stereo for my car with an auxilery input. Problem solved.
  7. dq1967
    dq1967
    Mar 14, 2004
    30
    thanx for all the advice.
    I have uncapped the volume limit, and the line output is even louder, but I still get hiss. Think it's the particular cassette adaptor. If anyone knows of a particular adaptor I'd be grateful for advice, or i may try the fm route....
  8. Neville Street
    Neville Street
    Jul 11, 2004
    290
    +4
    There will be a Dension ICE link for linking an iriver H10 to Peugeot stereos (Clarion) in the next month or so (about £100 apparently). In the meantime people suggest the Sony cassette adapter is a good bet. I just ordered one on Amazon for £14.49. NS
  9. HD3
    HD3
    Again what i suggested in another thread:
    "Rather than using a transmitter why not chose a FM Modulator/Oscillator
    such as this- http://www.maplin.co.uk/module.aspx...o=44128&doy=6m9
    You connect the device to a lineout/ head phone out on your mp3 player and you plug a lead into the FM input of your car radio. (and don't worry, you don't lose your fm singals as they have a "Pass-through FM aerial connector"
    Perfect for a sound q boost better than FM transmitters and likely better than tape. The best is having a "aux" in on your radio/CD but not many have that function.
    As for MP3 players, i don't think you can go wrong. Get something you like
    P.S- I made one from a soldering kit. "
  10. Neville Street
    Neville Street
    Jul 11, 2004
    290
    +4
    hd3 - link not working. Do you have to switch off rds & tune to a specific frequency to use a modulator? NS
  11. HD3
    HD3
    The link was ok on another thread for a few days, looks like its changed-
    Try this - http://www.maplin.co.uk/module.aspx?ModuleNo=44128&doy=10m9
    If it don't work do a search for FM FM Modulator of the maplin site.
    Sorry, i can't answer that question, I have no idea. I know very little about RDS (RDS is just radio text, isn't it EOS?) but don't know anything about it. I guess it stops a CD playing for the traffic news of your current station? Then i don't think RDS/EOS would work.
    With the transimitter i would imagine you would be in the same situation.
